Not sure, but it appears i cannot create a topic or tag. I am perhaps untrusted, which makes all the sense in the world. I want to add a comment somewhere about the “fundamentals” section of the manual, but in the meantime, this “it still has many valuable information” in about this forum contains a very common error: in English (unlike most every european language) information is (usually) uncountable, which means “many” should be “much”: much valuable information. English treats information like water; French etc. treats it like marbles. And…how can i create a topic?
Welcome @HelmZalee!
You’re right, see New User restrictions, and you’re also right, it is there for a reason.
The old forum is still flooded with spam registrations and it has long started here. But here it’s a matter of admins and moderators and no longer the whole community.
Concerning your questions, you’re trust level was just raised and you can now use the full power of the forum.
For the manual, please have a look at the Manual Source on GitHub.
If you are uncertain, you can start a new topic here in the Documentation channel to discuss your issue.
Otherwise you can create an issue on GitHub or even make changes, which will create a pull request for direct merge.
Further information at LibreCad wiki faq (Can I Easily Contribute on GitHub) or the GitHub Wiki (How to contribute).
