Hi everyone,
I am looking for a practical way to copy the automatically calculated numerical value of a dimension object to paste it into another document or program. However, I have run into some workflow challenges while trying to do this.
Here is what I have experienced with the current methods:
- Using the Properties window : The label field naturally appears as
<>, so I cannot select or copy the actual raw value measured by the program from there. - Using the Explode tool: I can explode the dimension to turn the value into independent text. However, since this destroys the dynamic structure of the dimension, I have to undo the action (
Ctrl+Z) every time, which slows down the workflow significantly.
Is there a shortcut, a plugin, or perhaps an alternative method that I might have missed to directly copy the measured value of a dimension without breaking the object?
If this is not currently possible, adding a read-only “Actual Value” field to the Properties window could be a wonderful improvement for future releases.
Thank you in advance for your ideas and help!
Version: v2.2.1.6-4-gec63aa3ab
Compiler: Microsoft Visual C++
Compiled on: Oct 28 2026
Qt Version: 5.15.2
Boost Version: 1.87.0
System: Windows 11
