Beginner problems in drawing line/rectangle etc
I copied that title (Beginner problems…) from a post on the old forum because I’m having I think a similar problem with a disappearing/reappearing hatch. I’m posting this now, after much exasperation, because when I selected a rectangle for some other purpose, a hatch pattern (solid fill) that had disappeared suddenly reappeared. No idea why. Oh, and clicking (well away from the problematic hatch-filled rectangle) seems to toggle visibility of hatch…that toggles a “selected” counter between 0 (hatch visible) and 1 (not visible), so the hatch might be on my “background” image in layer 0. why the hatch would have been on layer zero I don’t know. Still working on understanding… Edit: clicking, which toggles visibility not only of the hatch in one rectangle but also the visibility of a circle, does not change the “current layer” reported bottom right of the dwg. And oddly, when the circle is NOT visible a rectangle IS visible (but without its hatch) - and when the circle is visible the hatch that sb in the rectangle is visible. Sheesh.
This sounds more like a selection/redraw issue than the entities actually changing layers. One important detail: the current layer shown at the bottom is the layer where new entities will be created; it does not necessarily show the layer of the entity you selected.
A few checks should narrow it down:
  1. Select the hatch and the circle separately and open Entity Properties to verify their actual layer, color and line/fill settings.
  2. Check whether the drawing looks correct in Print Preview or in an exported PDF. If it does, the geometry is probably fine and the problem is only the on-screen redraw/selection overlay.
  3. Force a redraw, then test the same hatch and circle in a new empty document. Also check for duplicate or overlapping entities and the draw order of the solid hatch.
  4. If possible, attach a small DXF containing only the affected objects, plus your LibreCAD version and operating system. That would make it much easier to distinguish a file/layer problem from a graphics-rendering bug.
If the objects still alternate visibility only when the selected counter changes between 0 and 1, I would suspect a rendering or selection-highlight issue rather than layer visibility.
Welcome @HelmZalee !
Always post info about your LibreCAD version (See Help/About). This helps to find out if this is a known issue and if it is probably already solved.
Hatch and its limiting contour can life on separate layers, so it is possibly intended behaviour.
Use Modify => Properties or Attributes to show and modify the layer of entities.
Thanks, sorry about that, here’s the Help/About:
Version: v2.2.1.5
Compiler: Microsoft Visual C++
Compiled on: May 2 2026
Qt Version: 5.15.2
Boost Version: 1.87.0
System: Windows 10 Version 2009
Win 10 must be the version in which the app was built. I downloaded the install exe 9/6/2026. I’m using Windows 11 Home V 25H2.
Many thanks for the reply. Unfortunately I have since closed (and now reopened) the app and cannot reproduce the problem.
Curious, though, about “Select the hatch…and open Entity Properties…” I can find no way to “…open Entity Properties” after selecting an entity. I can see properties by (1) clicking Tools/Modify/Properties then (2) clicking on an entity.
