There are various ways to create an ellipse. What is the easiest way of finding the Ellipse Foci Points to help set-out?
aka String and two pins method.
Create an Ellipse by foci points makes only sense, if you already have them, e.g. from another drawing or given parameters.
With center, angle and minor/major radius math can compute the foci points.
LibreCAD does this math when you create an Ellipse with the Axis tool.
Then you can use Snap Center to catch the foci point, or select the Ellipse to make the foci points visible.
