New to this forum. Experienced with LibreCAD but I may have inadvertently changed the wrong setting. My circle radius is now double the length of the number I input. Same with vertical and horizontal line lengths.
Welcome @Ratty1978 !
What comes to my mind first is the Length Factor in the Dimensions tab of Current Drawing Preferences. This factor multiplies the real measurements of an entity for annotating. It must be 1 if the drawing is 1:1.
To understand your issue and support you, please:
- post the LibreCAD version and platform/OS you use
- add more details, e.g. how do you detect that the entities are twice the value
- check the coordinates and values with the
Modify/Propertiestool - create a small sample file, that shows the issue and append it to your reply
Solved it. Actually Copilot solved it. The setting in Options → Current Drawing Preferences → Dimensions has “Length Factor” as a subcategory under “Text size & position” and I set it to 2 when I set Text Height to 2 mm. Turns out “Length Factor” is for the whole drawing, and is not limited to “Text size & position”, if it anything to do with text size at all.
Length Factorin theDimensionstab ofCurrent Drawing Preferences. This factor multiplies the real measurements of an entity for annotating. It must be1if the drawing is 1:1.
As I suspected ![]()
