I started Technical Drawing, as it was then called, in school, over 65 years ago. Yes I go back that far! Later, at college, it became Engineering Drawing, and the subject has always been a favourite and interest of mine.
Back in the day at school, it was drilled into me that construction lines should be very feint, not heavy and prominent. The teacher used to stand in the aisle between the desks, look at your drawing, and say, if I can see your construction lines from here, they are too heavy. That concept has stuck with me.
I am starting off in LibreCad on a Mac, after years using TurboCad for Mac. So my practice has to have a Construction layer, with colour Cyan and a thin line width. Being brought up using pencil on paper when I migrated from paper to computer I stuck with a white background - I am happier that way. Yes, I know a lot of people, and the default on many CAD packages, is for a black or even blue background, and I know that for some it makes it easier on the eye to work with, but I like white. So thin cyan lines on white work well.
So when I started using LibreCad, I was pleased to find that each layer could have its own construction line option; I didn’t have to make a separate Construction layer, or so I thought. Except, that clicking construction on a layer can be a nightmare. The drawing space can be covered by lines all the same colour and thickness going everywhere - trying to decipher which are construction and which are the entity can be difficult or tricky, or even impossible!
So, this has been a long winded way of asking, is it possible to modify the construction aspect of a layer, by giving it a thickness of say 50% or whatever of the nominated line thickness of that layer, if not also another colour? Preferably as a downloadable update?
And please don’t say well the programme is open source, you can modify it yourself without also giving detailed instructions to do so as I would not have a clue on how to do that!
Thanks for reading this, Chris
